von LANZD3016 » 09.08.2017, 21:30
Hi friends, good night, I need to change the cylinder asparagus that holds the cylinder head, does anyone have any experience? They go out easily or there may be some leakage of refrigerant
LANZD3016
- Benutzer
von Rohoelzuender » 10.08.2017, 10:55
Hello,
I don´t know if they will come out easily but normally there will be no leakage of cooling water. If you want to take those parts away first you have to drain the water, then the cylinder head itself.
Regards Gordon
- Platin
von LANZD3016 » 11.08.2017, 22:14
Thank you, my fear is not being able to loosen the asparagus or that when it finishes the new ones have leaks by the threads of the asparagus
LANZD3016
- Benutzer
Mitglieder in diesem Forum: 0 Mitglieder und 107 Gäste
