Found
all the english stuff about Lanz Bulldog tractors
Found
Beitragvon patfinistere » 18.08.2006, 06:26
There is a possibility that I may be able to buy a Percheron A (the French Lanz) in bad condition in the near future.
I believe that it is basically the same as a 8506? Am I right???
My question is what is the weight of this tractor as I will need to transport it some distance on a trailer behind the Land Rover.
If I do manage to clinch a good deal for this tractor I will be asking for your help on this board in the future.
Best wishes
Pat
Pat
perso.wanadoo.fr/kostalan-life/
patfinistere
Beitragvon Theo S. » 18.08.2006, 09:51
Hi Pat,
the Percheron is similiar to the 25 h.p. Lanz D7506. So you can calculate the weight from 1.800 up to 2.000 kg.
Theo
Theo S.
Administrator
Beitragvon patfinistere » 18.08.2006, 22:09
Thanks Theo, in fact I looked at a photo of the tractor after posting and found the number and weight on the identification tag, it says 2T500. So you were ijn the right area, will be a bit heavy for my 2 ton trailer, but it is not too far on minor roads, Still it is not ours yet.
Will keep you posted, Had the 5506 out for it's first run this afternoon since last September when I started taking it to pieces, it is not completely finished, but it will be at St Caradec for the regional ploughing match.
Best wishes
Pat
Pat
patfinistere
Zurück zu Lanz-Bulldog - in English
Mitglieder in diesem Forum: 0 Mitglieder und 57 Gäste
